TO
35 factory colors
Phil / Arizona
02-23-2003 16:49:08
Restoring l955 TO-35 that has what appears to be factory red sheet metal with grey iron. All reference materials refer to metallic green iron with ????? ??. THANKS!
Paul in NM
02-25-2003 06:20:54
 Re: TO - 35 factory colors in reply to Phil / Arizona, 02-23-2003 16:49:08
Phil, TO-35's had a colorful history. They began with gray/metallic green in late '54 and remained that way until the late spring of '56 when a few sported beige sheet metal with metallic green castings. Then they switched to beige/flint gray until late 1957 when they began to paint them red/flint gray.
For a complete run-down on the transition, I can supply you with a copy of Issue #5 of the Ferguson Furrows newsletter which is devoted to this fascinating subject. Send $2 to Paul Nelson, 4140 Stryker Road, Las Cruces, NM 88005.
Paul Nelson,
Editor
Ferguson Furrows
Dick, Sonoma,Ca
03-12-2003 23:58:33
 Re: Re: TO - 35 factory colors in reply to Paul in NM, 02-25-2003 06:20:54
Paul
Would the FE35 be painted the same as it's contemporary TO35?
Thanks
Dick
Dick, Sonoma,Ca
03-12-2003 23:57:28
Paul
Thanks
Dick
