TO35 governor
Richard Friedri
02-08-2003 16:22:09
Hi I have a 1955 TO35 that the governor is not working. There seems to be some action on the rod across the front from the governor housing but it has no effect on speed controll. Engine will race badly or will bog down under load.I replaced a missing spring that hooks to the goose neck but that did not help. I tried making some adjustments using the I&T manual but it is not much good. (why can't you find factory manuals for the 35 series only see TO20& TO30 or MF35). Do these governors break down? Maybe I should see if there are any balls from the governor asmbly in the oil pan. Any help or thoughts would be helpful. Kinda run out of hands trying to position the hog, conrol engine speed and steer all at the same time. Thanks. Richard
Randy
02-10-2003 10:40:51
 Re: TO35 governor in reply to Richard Friedrich, 02-08-2003 16:22:09
My manuals say they're for TO35 and MF35. They are the same tractor.
