Wheel removal
Kevin
02-07-2003 14:02:10
I have read several times in this forum about steering wheel removal and using a bearing puller. How would you remove one that is really rusty and not enough metal to use a puller. I've tried but the puller keeps coming off because of the lack of surface for the puller to grip to. Could you use a cutting blade on an angle grinder and cut it off? Any ideas would be appreciated.
Ray G
02-08-2003 07:23:03
 Re: Wheel removal in reply to Kevin, 02-07-2003 14:02:10
If the wheel has a single key holding it from turning I have carefully drilled the key out then when the steering is on full lock managed to turn it on the shaft. You only need the very slightest movement then it should come off no problem. This will not work on splined wheels.
phil(va)
02-08-2003 07:00:27
Sometimes you can loosen the nut and after using penetrating oil and or heat you can sit in the seat and grasp the wheel and work it off. Don't remove the nut, however, because when the wheel does pop off you may roll over the back of the tractor.
pat pa
02-07-2003 14:57:00
hi kevin to remove steeringwheel remove acorn nut and replace with a double length nut screw a3inch bolt in to nut to tighten down on steering shaft tight tap head of bolt with a heavy hammmer and tighten down on bolt as you tap wheel will come up this works for me hope this helps pat
Roger
02-07-2003 14:17:57
Kevin;
Try a split-collar under the hub of the steering wheel so that your puller has a good surface to grab. This, after you,ve applied a rust buster repeatedly, over time, maybe a week or so. Usually lots of patience and determine is required for this type of thing. If all else fails, you could always cut it off and buy a new one! :-)
Roger
