Procedure To Replace I/E Mainfold.
Jeff
02-04-2003 13:57:50
My manifold is rusty, weld repaired, and just plain ugly. I also am blowing exhaust fumes from the manifold to exhaust joint onto the air intake.
I am looking to replace the manifold. It looks straight forward, however every machine has it's quarks.
I am looking at the following:
a) remove manifold to exhaust clamp and then remove muffler from tractor (horz. type)
b) Remove manifold from engine block (10 nuts?)
(Looks like some will be tough to get to unless the fuel tank is removed. Thoughts?)
c) Replace gasket place on new manifold.
d) replace gasket and reattach exhaust and muffler.
Is that about it or am I missing something?
Jeff
Frank
02-07-2003 21:48:25
 Re: Procedure To Replace I/E Mainfold. in reply to Jeff, 02-04-2003 13:57:50
I think you are on the right track. You will need to remove the gas tank. After the new intake is on, run the tractor until hot and then retorque the nuts. Do this two or three times. Spray a penetrating oil on the nuts daily for a few days before you try to loosen them.
Frank
TE20 - 1948
02-05-2003 04:13:44
Oops, I have a TE20 '48.
Jim W
02-04-2003 17:30:15
What model of tractor?
Jim W
