Lift question
Michael
01-30-2003 20:02:06
I have a '51 TO30 tractor. I'm not sure if I am trying to overload my tractor or if I need to replace the seals in my lift. My dad's '72 Massey Ferguson will either lift the object connected to the boom pole or else lift the front tires off of the ground. My friend's '52 8N will do the same thing, but my tractor will not. I've also noticed when the bushhog is lifted when bushhogging and I try to change gears, the bushhog drops slightly until the gear is shifted.
James, UK
01-31-2003 00:24:41
 Re: lift question in reply to Michael, 01-30-2003 20:02:06
From what you've said, it sounds like you may have a leak on the lift cylinder seals, or it could be that the relief valve is operating early.
Take the RH inspection cover off, and lift the hydraulics with something heavy attached. Then switch the tractor off and look inside the back end to see if there is oil leaking/dripping down from the top cover area - if so your leak is up there in the lift cylinder.
If not, suspect the relief valve - and run the tractor with the same implement lifted to see if there is turbulence/roiling indicative of a relief valve operating early.
Also, don't forget that the TE/TO series had an early hydraulic system which may be designed to run at lower pressures than your Dad's tractor.
However, you should still be able to get the tractor to 'sit up and beg' with a good load on the hydraulics.
Do NOT put your hands in through the inspection cover with the engine running - obvious I know, but ought to mention it anyway.
James, UK
