TO 35 Hydrolics
Kevin
01-29-2003 07:24:46
When I first baught my 55 TO35 6 months ago the lift could only be operated by the draft control. Lifting the position control did nothing. Then one day the the position control started working and moving the draft control up or down did nothing. When this happened the lift would only go up half way. Last week I was using my box blade and the both levers started to operate the lift. I could use the draft to move the lift all the way up no matter where the position control was but if I had the draft control all the way down the position control would only lift the blade half way up. In the middle of grading oil started seeping out from beneath the seat. So I emmediatly drove the tractor to where I park and cut it off. I waited about an hour and cranked it back up again and when I used the position control to raise the lift oil started spraying out from beneath the seat which covered me and the tractor. I haven't tried using it since. What do you guys think the problem could be?
