TO-30 ORC Removal and front end loader
Mike
01-26-2003 13:02:44
Can anybody tell me the method of removing the ORC from the PTO shaft of my TO-30(just bought the tractor and am new to it's workings)and is a front end loader available. If so, where is the source of the hydraulics for the loader.
Thanks for any info.
Mike
Dale in WV
01-26-2003 18:01:07
 Re: TO-30 ORC Removal and front end loader in reply to Mike, 01-26-2003 13:02:44
Paul is correct. The grease fitting was opposite basically a filler plug on my model. Removing both allowed me to remove the pin.
Dale in WV
01-26-2003 13:33:51
Mine was attached to the PTO shaft via a pin that went through the ORC and into the PTO shaft; the pin was held in place by a screw -- something like a wide set screw. Remove the screw and drive the pin out with a drift punch. When I first got TO-30 it was covered in so much dirt and accumulated oil/mud, I had a tough time finding the screw.
Paul (WI)
01-26-2003 14:40:51
 Re: Re: TO-30 ORC Removal and front end loader in reply to Dale in WV, 01-26-2003 13:33:51
I remove the ORC on my tractor by first removing the grease zerks on the ORC and then driving the pin out.
