Starter
Stan
01-26-2003 12:15:09
Delco makes a 12v starter that will fit a TO-30.
If anyone knows the part number I'll give you my first born.
Herb/pa
01-28-2003 04:59:03
 Re: starter in reply to Stan, 01-26-2003 12:15:09
The old 6 volt starter works fine with a 12v neg ground Delco alternator. Don't keep cranking starter if it doesn't start right away.
Stan J
02-15-2003 09:22:10
 Re: Re: starter in reply to Herb/pa, 01-28-2003 04:59:03
What a coincidence! My starter is also busted. I'm looking for anything that will work, 6 or 12 volt. Rebuilts are over $200. When you ask for help or advice everyone tells you to stick with the 6 volt and wire for 12volt. Not my problem. I'm checking to see if the starter can be welded and rebuilt. If I find anything out I'll let you know. Stan from Tenn
