TE-20 lift problems
Carlson in Miss
01-21-2003 09:49:17
I used the lift on my tractor a few days ago in cold weather. It took forever, but the lift eventually raised but then would not drop. I left the control lever in the down position overnight and found the lift in the down position the next morning. SINCE THAT DAY, THE LIFT HAS NOT WORKED. I removed both side inspection plates and found fluid to squirt around the high pressure tube somewheres in the area of where the tube and pump connect.
The manual says I must break the tractor in half to repair. Can the repair be made from below? What usually breaks in these instances, the pump fittings or is the tube cracked???
I need your help....
Gordon
01-21-2003 17:23:01
 Re: TE-20 lift problems in reply to Carlson in Missouri, 01-21-2003 09:49:17
The orings are leaking there is about a 3" plate in front of seat and to the right side.That the cover off and replace the orings top and bottom.
Charlie
01-22-2003 00:11:42
 Re: Re: TE-20 lift problems in reply to Gordon, 01-21-2003 17:23:01
Thanks Gordon!!!
