Starter ring to20
pferguson
01-19-2003 17:43:36
Just wondering if the starter ring on the flywheel can be welded back on or not.....Mine just seperated from the flywheel...Allso how does one set the 3 throwout fingers on the flywheel? Thanks all....Paul
pferguson
01-20-2003 06:23:19
 Re: starter ring to20 in reply to pferguson, 01-19-2003 17:43:36
Well the starter ring just slides on and off with very little tapping of the ballpeen hammer...Also it looks like it was "staked about every 1/4 inch or so. Is it possible to have a flywheel balanced? Thanks
James, UK
01-20-2003 06:52:52
 Re: Re: starter ring to20 in reply to pferguson, 01-20-2003 06:23:19
It would need to be staked every quarter inch to stand even a chance of staying put. This is a new one on me.
Yes, you can get flywheels balanced - it would be worth trying your local Mr. Clutch (or another transmission 'specialist') to see if they would do it for you.
I would still go for the Loctite approach over welding or staking though. If its a sliding fit, that'd be good for Loctite. You would get a good surface area of bond - so would be a strong fix. Two part epoxy resin adhesive would also work, and would take longer to cure so less risk to flywheel. Degrease well, though.
It is possible that a previous owner needed to replace the starter ring, and assumed that he had to turn down the OD of the flywheel to get the new ring to fit - hence the problem you have now.
Is all I can think of - anyone else help??
pferguson
01-20-2003 07:02:43
 Re: Re: Re: starter ring to20 in reply to James, UK, 01-20-2003 06:52:52
Thnaks for your help, its well appreciated...Paul
James, UK
01-20-2003 00:52:01
The starter ring is normally fitted to the flywheel when hot (about 500 deg. C). As it cools, it shrinks onto the flywheel and hopefully stays there.
Welding this into position will change the structure of the steel used, probably making it softer by annealing it - so it will wear fast on the teeth. Also, the weld - beaded or not, will throw the flywheel out of balance, which could be catastrophic, and will cause excessive wear on the crankshaft rear main bearing.
In other words, my recommendation is don't weld it. There was a posting a few months back on this subject - so it would be worth looking through the archives - I think someone came up with a source of supply for a new starter ring.
If not, and you are quick with a fly press and your starter ring is that easy to slide on again, you could try something like Loctite 407, which has a longer curing time than some, and provides a good strong bond. Watch your fingers though!!
Just a thought.
