Jim W is there a 6 volt wiring Diagram available?
Jeff
01-17-2003 12:45:51
The TE20 I have has been re wired and the lights are not hooked up. I would like to fix the wiring the rest of the way.
I have a 6 volt system. Any suggestions on wire guage?
Jeff
phil fenner
01-17-2003 21:36:42
 Re: Jim W is there a 6 volt wiring Diagram available? in reply to Jeff, 01-17-2003 12:45:51
Jeff, as Jim W indicated, I have looked into this issue. I am not sure what you meant by "rewired", but for the headlamps, 14 guage is ok and 16 guage inside the lamp if you need to do that.You can use 14 guage to the back lights as well. There was a main wire with a 20 amp fuse in the original wiring which went to the power connection in a switch. Since this wire takes all the load from front and back it should be 12 guage to be compatible with the 20 amp fuse. For your tractor you should install a separate light switch just left of the ammeter 2 and 1/2 inches.
Phil Fenner
Ray,IN
01-17-2003 19:04:01
Visit this website for the original schematic. Select electrical in the left column.
Jim W
01-17-2003 14:40:28
Do you mean "what is the wire gauge for the lights for a 6 volt system?"
Phil the lighting authority Fenner is best suited to answer this question.
You out there Phil?
Jim
todd(MI)
01-17-2003 13:23:01
SEND ME YOUR EMAIL ADDY I WILL SEND YOU WHAT YOU NEED. I DON'T KNOW HOW TO POST PICS OF DIAGRAMS I HAVE COLLECTED HERE AND THERE.
TODD
