Is it a TO20 or TO30?
Ron V
01-17-2003 06:00:55
Just bought a Fergeson that the guy thought was a TO20, but the serial # plate says "TO 99983". In checking the numbers on this site, the TO20 in 1951 started at 39163. Did they make that many in 1951, or is it a 1952 TO30? What is different on the TO30, or are they just later models? I'm new to the Fergeson model, having been raised on JD 2 bangers. Any help greatly appreciated!!
phil fenner
01-17-2003 11:56:12
 Re: Is it a TO20 or TO30? in reply to Ron V, 01-17-2003 06:00:55
The TO20 finished at 60000 and the TO30 finished at 140000, so you have a TO30!
PhilFenner
dennis in Ma
01-17-2003 07:23:00
Check the engine. The 20 had a Continental Z120 and the 30 had a Z129. These numbers should appear on the block. The primary visual difference in these engines is that the Z129 has an outside oil filter while the Z120 has it in the pan. The Z129 is sveral HP larger but most all parts are interchangeable.
