Lower lift link
linch pin retaining chain
Steve Putman
01-09-2003 16:50:17
I am replacing the rh lower lift link (arm) on my TO-20. The replacement arm is a used one in good condition. At the implement end of the link there is a sheet metal retaining clip in which the linch pin is placed when not in use. There is a small chain which connects the linch pin to the retaining clip. On my old lift arm the last link of the chain seems to have a messy weld to close it over the small hole in the retaining clip which is evidently there for that purpose. Question: What is the "official" method of connecting this small piece of chain to the retaining clip?
Ray,IN
01-09-2003 19:23:26
 Re: lower lift link - linch pin retaining chain in reply to Steve Putman, 01-09-2003 16:50:17
The "retaining clip" is split at the chain attachment hole. Bend each side in opossite directions enough to slide the link into it, then bend them back to where the ends are flush.
Steve Putman
01-10-2003 08:33:55
 Re: Re: lower lift link - linch pin retaining chain in reply to Ray,IN, 01-09-2003 19:23:26
Thanks Ray. I'll check that out.
