TO35 standard 23C injector lines needed
Scott Tomlinson
01-07-2003 16:12:54
Anyone know where a person can get their hands on some injector lines. In particular #2 and #3 cylinders. Also need four cylinder preheaters or "glow plugs" for the same tractor. Inherited the tractor from Grandmother. It was in bad shape. I have overhauled it and put a fresh paint job on it. Would like like to get it back to great shape but needs a lot of little parts here and there - lights, rubber boots etc. Is there a place a person can buy this stuff.
James, UK
01-08-2003 00:25:59
 Re: TO35 standard 23C injector lines needed in reply to Scott Tomlinson, 01-07-2003 16:12:54
I'd try your local diesel pump and injector service centre - they usually carry stocks of suitable tubing and fittings so that you can make up your own injector lines - and will advise on replacement heater plugs. Take your old lines and a plug with you so they can get the right size tubing and compare your heater plug with any they have on the shelf.
These guys can be a mine of information, so it's worth a few calls.
As far as the other parts go, someone on this board nearer to you should be able to help. I can give you contact details for several companies I've used, but they are all over here in the UK, so probably not much use to you.
Good luck.
