TO-35 Loader
Roger W
01-07-2003 16:00:18
I have the chance to buy a TO-35 and would like to hear from others about using a hydraulic loader on a TO-35. It would be helpful to know a) How well does a TO-35 handle a loader b) What loaders fit a TO-35 c) How hard/easy are the loaders to find d) what do they typically cost e) How hard/easy (and $) is it to add hydraulics/PS to a TO-35
Thanks,
Roger
David
01-08-2003 06:44:14
 Re: TO-35 Loader in reply to Roger W, 01-07-2003 16:00:18
This is just a personal point of view but I don't think they handle them too well at all.
I worked with a 35 loader for years, then tried a more modern JD2030 with spool valves and power steering. I wouldn't have swapped back to the 35 again. Years later I eventually got to use a JCB 406 loading shovel and now I wouldn't use ANY tractor mounted loader in preference to it. I guess it depends on what level of performance you come to expect and can be happy with. Also depends on what you intend to do with it and how often. They do work ok but understandably are just are not a patch on more modern kit. Lack of power steering is major disadvantage although you do end up with arms like Popeye from wrestling the steering. Its also quite hard on the various front axle bearings.
I think fitting power steering and spool valves to a 35 is likely to prove more difficult and expensive than swapping the tractor for something else with them (and a loader?) already fitted. That said you can operate a loader from a 35 with no special valves provided you are willing to work with a mechanical trip for the bucket/fork.
Just my thoughts on it.
