Part identification
Brian McDonald
01-06-2003 20:29:17
My TEA20 leaks hydrolic fluid,the leak appears to be from a hole located near the joining of the engine to the transmission housing.The hole is centered evenly with the drain bolt.There doesn't seem to be any leaking around the seal,what is the hole for?any help would be appreciated.Would anyone know of a product that revives the seals in the tran\diff\hyd housing?Thanks
Dan, IN
01-07-2003 06:16:57
 Re: Part identification in reply to Brian McDonald ,Ont., 01-06-2003 20:29:17
I heard of a product called "Seal Lube" that rejuvinates rubber seals, and can be used in transmissions, engines, differentials, and power steering units. I haven't used it myself but am considering it this spring when I start using the tractor more frequently. I have the same problem, but don't have the time to split the tractor right now. The phone # is 1-800-434-9192, if you use it let us know how it works out. Dan
James, UK
01-07-2003 01:02:49
That hole is at the bottom of the clutch housing, and was put there to allow oil leaking past either the gearbox input shaft, or from the engine rear main oil seal to drip out onto the floor.
The only real fix is to split the tractor (see forum archives for more info) and replace all the seals you can get at, and for good measure, do the clutch as well, as it may be getting oiled up by the leak, and will fail prematurely because of oil soaking.
I did hear of a product you could add to revive seals, but cannot remember its name - at the end of the day the real fix is to do the job properly - sorry.
