TEA-20 Alternator bracket?
Paul in Califor
01-05-2003 21:29:32
Does anyone make a bracket to install an alternator like a single wire Delco on a old Fergason TEA-20, yes, Standard engine? If so please let me know where and how much if possible.
James, UK
01-06-2003 07:10:39
 Re: TEA-20 Alternator bracket? in reply to Paul in California, 01-05-2003 21:29:32
I've got an old Lucas alternator fitted to the original bracket - for an alternator you need to use longer bolts on the bottom two dynamo mountings, and add some (lots of) washers to remove the slack in the fitting.
The adjuster bracket should still fit and give just enough to get the belt tight.
I've never seen an aftermarket bracket for sale.
Hope this helps.
