TO-20 TIMMING
STEVE MOYER
12-31-2002 10:23:01
I HAVE A 1950 TO-20 CAN ANYONE TELL ME HOW YOU ADJUST THE TIMMING? WHAT IS THE SETTING? DO YOU NEED A SPECIAL TIMMING LIGHT (VOLT)? LOOKED IN THE ARCHIVES BUT FOUND NO HELP. THANKS
Ray,IN
12-31-2002 19:49:45
 Re: TO-20 TIMMING in reply to STEVE MOYER, 12-31-2002 10:23:01
Move engine till #1 cylinder is on compression stroke (thumb covering spark plug hole). Look in timing hole in bell housing and move engine further till the 6* line (BTDC)on flywheel is aligned with the groove/notch in timing hole. The points should be just starting to open, if not, rotate distributor until they are.( this opening point establishes when the spark occurs)HOWEVER! You must have the points properly adjusted to 0.022" first to get precise timing.
