Replacing Lift Arm Supporting Pins......
C.T.
12-21-2002 17:00:24
I posted earlier but for some odd reason it didn't take,but what the heck :).I need to replace the lift arm pins on my TO 20 Ferg and was wondering if there was a nut on the end of the pin inside the rear of the tractor.And how do i go about doing this.Thanks for any reply and MERRY CHRISTMAS.
marlowe
12-21-2002 18:26:11
 Re: Replacing Lift Arm Supporting Pins...... in reply to C.T., 12-21-2002 17:00:24
are you asking about the lower 3 pt. lift arm pins ?if so yes there is a nut on the in side and you have to remove the axel housing so you have to drain the oil in the rear end and remove all bolts and slide housing out. it's not real hard if you have the right tools and jacks and stands. make sure you have 2 new gaskets
