To-35 ring gear
ted
12-20-2002 11:54:25
overhauling my 1955 to-35 with the 134 cont. Found that the ring gear has a worn area of about 5 inches wear it comes to rest. Can I remove and turn the gear a quarter turn? The book mentions heating to 500 degrees on replscment. Is there more involved , help please. Thanks Ted
James, UK
12-21-2002 05:36:05
 Re: to-35 ring gear in reply to ted, 12-20-2002 11:54:25
Ted,
Look back in the archives - I think the subject was Starter Ring Gear - the thread will cover most if not all your questions, and yes, you do need to heat to 500 degrees, so the ring gear will shrink to fit on cooling. I don't think rotating it will help your problem. If it works, don't fix it.
My two pennies worth.
