Lift control safety chain
Steve Putman
12-17-2002 20:51:51
I've seen mention of "lowering the lift control and putting on the safety chain" in reference to using a drawbar on a Ferguson. I can't find a drawing or photo of what exactly this is or means. Can anyone enlighten me?
Thnaks, Steve
Kevin
12-18-2002 18:12:17
 Re: Lift control safety chain in reply to Steve Putman, 12-17-2002 20:51:51
I can't find the Fergy book, but in my Dexta book, There's the old Ford chain setup.
Scott Morrow
12-18-2002 15:22:53
Steve These are the same as the ford one's. They are available new from a place called N-new. I will look for my catalog and get back to you with the info. Scott a Ferguson nut.
Paul in NM
12-18-2002 13:51:34
Steve, to the best of my knowledge, the safety chains you refer to were identical to those used on the Ford 9N/2N. I'm not sure about the 8N.
Paul
phil fenner
12-17-2002 22:19:29
Steve, I believe you can find a picture in the ooperator's manual. When you install the stays of the drawbar, you can't raise the lift without bending the stays, so the finger tip control is "locked " in the down positon using the safety chain to prevent that from happening .
Phil Fenner
Steve Putman
12-18-2002 10:48:43
 Re: Re: Lift control safety chain in reply to phil fenner, 12-17-2002 22:19:29
Phil, I won't be able to get to my TO-20 Operator's Manual until Friday. I did look at it before I did the posting here. Do you have a page reference?
Is the chain the same as is used on the Ford N? Sheet metal end links, with an oval, stamped with the warning message, in the center of the two lengths of chain?
Thanks
phil fenner
12-22-2002 11:11:53
 Re: Re: Re: Lift control safety chain in reply to Steve Putman, 12-18-2002 10:48:43
Steve, that sounds correct per my ops book and parts book. I don't actually have one myself, as I am still looking fr an original. My parts book shows the same part for 20/30/9N/2N. This chain is described on page 12 of my 30 ops manual and page 98 of my parts book(issue 8/57).
Phil Fenner
Chris Chambers
12-23-2002 02:22:01
 Re: Re: Re: Re: Lift control safety chain in reply to phil fenner, 12-22-2002 11:11:53
For a picture try the front page of www.fergiebitz.com
He's been seeking one lately.
Chris
Steve Putman
12-23-2002 12:24:14
 Re: Re: Re: Re: Re: Lift control safety chain in reply to Chris Chambers, 12-23-2002 02:22:01
Thanks for all the comments. I also found a picture on p. 6 of the "Operation and Maintenance" booklet for the TO-20. That illustration is actually a cutaway of the whole traactor, but there happens to be one of these safety chains in place on it.
Steve
