SAFETY START SWITCH Testing
richard
12-16-2002 05:51:09
I would like to test the neutral safety switch in my to-35. Is this correct, when the tractor is in neutral it should have some reading in ohms (closed switch) and when it is in gear it should have an infinite reading (open)?
Paul in NM
12-18-2002 13:58:05
 Re: SAFETY START SWITCH Testing in reply to richard, 12-16-2002 05:51:09
Richard, there was no "S" starting position for the shift lever on a TO-35.
Paul
Tex Ferguson
12-17-2002 17:32:10
Richard, I'm going to guess that the only way you can close the switch and get a current flow is to move the shift lever to the S position(right and forward). I believe this causes a pushrod to activate(close) the switch; in neutral or in any gear, the switch is open. Good luck!
Tex
richard
12-18-2002 05:23:33
 Re: Re: SAFETY START SWITCH Testing in reply to Tex Ferguson, 12-17-2002 17:32:10
Thanks for the info everyone. I was wondering why my starter button wasn't working. Pulled the boot of the safety switch and the wires fell out. Don't know yet whether it's the wiring, connection or switch. I'm get a bit tired of using a screw driver on the solinoid to start it.
Phil (VA)
12-16-2002 06:54:32
I have not had occasion to test that on my TO-35, but I would say you are correct. Your theory sounds right to me.
