To30 hydraulics help
scottwv
12-15-2002 13:09:39
Is it possible to run a front loader with the internal hydraulics on this tractor and how does it work. I know where the ports are but need to know how it operates and how to connect it. I have an auxillary valve for the loader. The loader is hydraulic up/gravity down with a 2 way bucket. Thanks for any help
Herb pa
12-17-2002 04:42:23
 Re: to30 hydraulics help in reply to scottwv, 12-15-2002 13:09:39
It will work off the tractor hydraulics, but you must remember when you put the clutch in the loader will come down. I have a snow plow on my 30 and it works this way. The best way is to install a front crankshaft mounted pump. This way you will have pressure as long as the tractor is running.
steveormary
12-20-2002 20:34:58
 Re: Re: to30 hydraulics help in reply to Herb pa, 12-17-2002 04:42:23
Herb,
If the loader comes down when you push in the clutch you have some bad seals somewhere or something not plumbed right.
steveormary
steveormary
12-15-2002 15:04:12
Yes there is but your best bet is to use a front mounted pump.
In a back issue of the Ferguson Furrows magazine is an article on how to modify the internal hydraulics plumbing to operate a loader. Seemed a rather simple project. e-mail me and I can put you in touch with the publisher of Ferguson Furrows and you can get back issues from him.
steve
