How do I get my TO30 lug nuts off?
Jerry Elam
12-11-2002 18:46:53
I think the previous owner may have used an impact wrench.
I'm talking about the bolts that hold the outer rim to the center rim or inner rim.
Jerry
Jeff
12-12-2002 06:46:52
 Re: How do I get my TO30 lug nuts off? in reply to Jerry Elam, 12-11-2002 18:46:53
My problem was not the nuts it was tring to remove the bolt from the loop. I eneded up taking it to the shop. (I needed a new rim any way.)
Jeff
Boogity - Ohio
12-11-2002 19:22:23
Jerry - I used a similar approach as Ford Man but I think I over did it. When a couple of mine broke I used a blow torch to heat them and I had more success. Any way you look at it, they're a tough nut to crack.
Ford Man
12-11-2002 19:04:18
Jerry,
I had to use a 3/4" drive breaker bar and a 4' long cheater pipe and then bounce on it to get them to break loose !
Once I got them loose , they came off just fine .
Good luck !
Ford Man
tman
12-11-2002 22:37:28
 Re: Re: How do I get my TO30 lug nuts off? in reply to Ford Man , 12-11-2002 19:04:18
thats what i had to do to same as ford man only i used the handle of my jackall lol whatever ya have when in need i guess
