TO-20 Lift Stuck
tokruys
12-06-2002 03:56:28
Had just a draw bar on and was pulling stumps when I noticed the lift "creeping" up. It's been maxed out ever since...
It's been 5 days and it still hasn't come down. There is a couple of inches of movement of the arms. I've loosened the adjustment at the spring (top link connection) and played with the draft control (sliding the pivot forward). In between I've been bouncing my weight (210 lbs.) on the end of a fence post trying to pry down on the lift...
Any other suggestions??
Thanks, Tom K.
tokruys
12-08-2002 18:48:39
 Re: TO-20 Lift Stuck in reply to tokruys, 12-06-2002 03:56:28
Got into my lift this weekend and found that the Control Fork had become disconnected from the Control Valve... Pulled the cover for inspection (didn't need to use the block of wood to spread the forks, since it wasn't connected) and found everything is good condition!
Needed to make a new gasket for the cover, drained the fluids and reassembled (with the forks tightened up a bit). I just need to pick up new Mineral Oil and test it out.
phil fenner
12-11-2002 15:46:07
 Re: Re: TO-20 Lift Stuck in reply to tokruys, 12-08-2002 18:48:39
Regarding the "block of wood" people mention, I never found that worked very well for me. What I found was I could easily spread the fork through the pump drain hole with a long bladed screwdriver and position the fork on the "T" without scraping knuckles, wrists, etc. Also works for disconnecting. Surprised how easy it is and nobody else has mentioned it.
Phil Fenner
Scott L.
12-08-2002 16:45:47
Tom,
I have a similar problem. I thought I had it resolved but currently mine is stuck up again too. You can usually isolate whether the problem is in the top
cylinder or the pump area by disengaging the PTO and carefully unscrewing the pressure test port on the pump casting (the one by your right foot at a 45 deg angle pointing forward. If you have water you will see that come out around the threads first. Milky hydraulic fluid would also indicate some water in the hydraulics. If you let the screw out just enough to drain It will take some time but the lift should drift back down as the fluid leaks out. If you back the plug out too far you will have oil splattered pants and the lift should drop like a stone. If the lift does not drop the top cylinder is stuck.
You may have a stuck control valve or a problem with your control linkage. With the lift up and the PTO disengaged take the inspection port off the right side where the hydraulic dipstick is. You should be able to reach your hand in and manually pull the control valve (in the fluid)towards the rear of the tractor. This should allow the lift to drop. Assuming it does If it does not the passage is either blocked with ice or some other crap. I think this is the case with mine
If it does then you may need to clean your control valve or play with the linkage spring inside the housing. On the TO-20 you can spread the control forks to disengage the control valve and slide it out without dropping the pump. To get it back into the control forks cut a small block of wood slightly longer than the T on the control valve to aid spreading the forks. It's a two handed job in a one handed space
I dropped my pump this summer, took apart the valves and flushed it on a parts washer for about 20 minutes. I did my best not knowing the exact configuration of the passages I was flushing. It lifted great but still dropped somewhat slower than I remembered. 3 months later it lowered very slowly. Now it doesn't move.
I'm going to tap off a pressure port and run a drain through a valve back to the transmission housing as a work around so I can plow.
Check out>Link
Good Luck.
Phil (VA)
12-06-2002 07:00:08
Sounds like stuck valve, perhaps relief valve. Anyway, how cold is it? Do you have any moisture in the system that could be frozen?
