Spin-on filter
Shawn in Ohio
12-03-2002 15:25:19
Hi does anyone make a filter conversion to allow for a spin-on filter to replace the cartridge filter on a TO30?
Randy
12-06-2002 23:59:25
 Re: Spin-on filter in reply to Shawn in Ohio, 12-03-2002 15:25:19
Shawn: I just did that on a 35 with the Continental Z134 engine. If you have the Cont. Z129, does your filter stick out at an upward angle on the right side of the block and take a Fram C3 or equivalent filter like a Z134? Does it use a round topped housing with a bolt in the middle at the top to hold it on? If so this set up might fit yours. Let me know if it matches and I'll send part numbers.
Terry G
12-04-2002 09:07:51
third party image
I added this one to my old TO-20 but it did take some machining on the oil pump and putting two holes in the block for the supply and return lines.
Terry G
Boogity - Ohio
12-03-2002 16:53:55
I thought about a spin-on filter adapter for my TO-30 when I overhauled the engine last year. I even went out and purchased a couple filters and went to a junk yard and gathered three spin-on filter mounting castings. I dropped my little project when other priorities popped up. But I really do not think it would be too difficult. My only stumbling block was that I don't have access to the machining tools required to either modify an existing filter mounting or to fabricate a new one. I know it could be done.
