TO30 ELECTICAL SYSTEM
CLIF C
11-28-2002 19:25:42
I RECENTLY BOUGHT A TO 30 AND WAS TOLD IT WAS CONVERTED TO 12VOLTS.EVERYTHING LOOKS ORIGINAL EXCEPT FOR THE BATTERY. THIS TRACTOR ALSO HAS NEGATIVE GROUND WHICH I UNDERSTAND IS NOT RIGHT. ANYONE HAVE A WIRING DIGRAHM OR A SUGGESTION ?
phil (va)
11-29-2002 06:25:27
 Re: TO30 ELECTICAL SYSTEM in reply to CLIF C, 11-28-2002 19:25:42
What Ray says. Also, if it has been converted to 12 volts, it probably is negative ground now. The 6 volt generator might have been converted to 12 volts, or (and this is usually the case) it may now have an alternator in place of the original generator.
Ray,IN
11-28-2002 20:31:54
This tractor originally was 6VDC pos ground. If it has been converted you must have a different generator, its nameplate will identify the voltage. You may view/download the original wiring schematic from:
