Which TO30 Thermostat?
Brent, IN
11-28-2002 06:45:22
Which is best -160 or 180 degree thermostat> The service manual says it should open around 160 and be fully open around 185.
Ray,IN
11-28-2002 20:42:18
 Re: Which TO30 Thermostat? in reply to Brent, IN, 11-28-2002 06:45:22
You may use a candy thermometer(ask wife first for continued good health!) and a pan of water atop the stove to check for proper operation of a thermostat. A good 180 deg F stat should begin to open near 160 deg and be fully open at 180 deg + - a few degrees. Running an engine below its operating temp will cause oil dilution and/or sludge formation, plug fouling, and increased fuel consumption.
Brent,IN
11-29-2002 09:07:57
 Re: Re: Which TO30 Thermostat? in reply to Ray,IN, 11-28-2002 20:42:18
Thanks both James and Ray for you help. I found out that there wasn't a thermostat in the tractor at all!! The guy who had it before me didn't install one! I found a new one at my AGCO dealer. He said it opened at 160 and was fully open at about 175 so I think I'm OK.
James, UK
11-28-2002 07:18:12
On the petrol/TVO engines, the hotter they run the better for efficiency - so go for the 180.
Diesel engines hate getting hot and bothered and will not tolerate getting overheated - it's a recipe for trouble - so run 'em cooler.
Have a good Thanksgiving.
