Interchangeability: TO-20, 30, 35 Cylinder Heads
Fruitfarmer
11-04-2002 13:51:01
Will either a TO-30 or TO-35 cylinder head fit a TO-20 block? If not, then why not? Can the difference be machined out?
Jeff (MN)
11-25-2002 20:52:17
 Re: Interchangeability: TO-20, 30, 35 Cylinder Heads in reply to Fruitfarmer, 11-04-2002 13:51:01
When I bought my 1949 TO-20 I pulled the head off for inspection and cleaning and found it had a crack. Rather than try a repair I found a head off a 35 at a salvage yard. It matched up exactly except for 2 oil channels that were not in the 35 head. I machined out the channels, bolted it on, set the valve lash, and when I fired it up, it worked! It's been fine for 2 years now, with about 100 hours on the head. My current problem is a worn carb. and I'm trying to decide between a new Zenith or a rebuilt Marvel Schebler TSX361...
Good luck.
Chuck (CA)
11-05-2002 19:40:17
The TO30 and TO20 heads interchange, but I don't know about the '35.
HTH
Chuck
Paul (WI)
11-11-2002 19:38:27
 Re: Re: Interchangeability: TO-20, 30, 35 Cylinder Heads in reply to Chuck (CA), 11-05-2002 19:40:17
The TO-20 and 30 heads may bolt on ok but I would wonder if the compression ratio would change. The combustion chamber part of the heads are different. I think that the TO-30 chamber is a lot deeper.
