Winterizing TE-20
Not Running
Terry
11-01-2002 10:12:40
Have TE-20, currently engine not running. Had been running recently, just down for minor repairs. I had not brought antifreeze (I'm sure it is real light on antifreeze) to proper level prior to shutting down for repairs. How do I protect engine, radiator,etc. parts from freezing until I get it running again?
David
11-01-2002 12:42:14
 Re: Winterizing TE-20 - Not Running in reply to Terry, 11-01-2002 10:12:40
All I've ever done with mine is to drain the water out of both the radiator and the block by opening the two drain taps. I've done that each winter since 1991 and it seems to come to no harm. I probably should leave it with antifreeze in it as leaving it empty if probably encouraging corrosion. I'm sure others will have more elaborate and probably more "correct" procedures but the minimalist approach above has been ok for me. That said I bought antifreeze for it this year. We don't get temperature much below -10C here usually although it can go lower.
Terry
11-01-2002 11:03:14
As a followup to above: No oil in crankcase. May have to winterize prior to putting oil and filter in since I'm having trouble getting correct oil filter!
Pete@easttn
11-03-2002 07:27:16
 Re: Re: Winterizing TE-20 - Not Running in reply to Terry, 11-01-2002 11:03:14
Oil Filter Wix http://www.wixfilters.com/filterlookup/index.asp# 51107
