Oil pressure and temp gages
jim (ky)
10-31-2002 12:18:00
Where does the oil pressure gauge line attach to the block on a to-30 z129 and also the temp gauge line thanks very much for all help. jim
Larry in Missouri
11-01-2002 12:22:23
 Re: oil pressure and temp gages in reply to jim (ky), 10-31-2002 12:18:00
I'm trying to remember where the oil pressure line goes. I believe there are 1/4" threaded holes on both sides of the block; I seem to remember having to move a plug from one side to the other when I got my short block. The temp sensor threads into the left side of the top casting where the top hose goes to the block.
Hope that helps,
Larry
Ray,IN
11-01-2002 19:39:19
 Re: Re: oil pressure and temp gages in reply to Larry in Missouri, 11-01-2002 12:22:23
The oil pressure gauge mounts on the right side of the dash. The oil line routes behind the air cleaner, under right side of fuel tank, turns down 90 deg. just in front of bell housing and attaches to a "L" fitting 2/3 way down on block if front of bell housing. Just had to redo mine, age and vibration ya'know.
