Wire guages
phil fenner
10-30-2002 19:34:02
I am looking for information from Ferguson that specifies the wire sizes for the electrical sytems and the light wiring harnesses. All the diagrams I have show color and routing only. Does anyone have such documentation or know for sure what the guages were so I can get mine up to the original design? Thanks.
Phil Fenner
Jim W
10-31-2002 08:02:59
 Re: wire guages in reply to phil fenner, 10-30-2002 19:34:02
Which tractor do you have?
Jim
phil fenner
10-31-2002 10:52:09
 Re: Re: wire guages in reply to Jim W, 10-31-2002 08:02:59
I have a TO30 but would like guages for other models as well if you have them. The wire harness part numbers for the lights are the same so I assume the guages used will be the same.
Phil Fenner
Jim W
11-04-2002 15:00:43
 Re: Re: Re: wire guages in reply to phil fenner, 10-31-2002 10:52:09
I thought I had this information but I don't, unfortunately. However, a given gauge of wire has a given current rating, so it would be possible to figure out the right gauge to use - but it may not quite be original.
I hope someone else has the answer to this as I ave a couple of wiring jobs to do myself.
Jim W
phil fenner
11-05-2002 14:31:53
 Re: Re: Re: Re: wire guages in reply to Jim W, 11-04-2002 15:00:43
Jim, I used current rating but this could give you a small wire size that may not stand uup to the abuse especially for a 12v system, so that is why I was trying to get the original sizes.
Phil
Jim W
11-06-2002 10:19:24
 Re: Re: Re: Re: Re: wire guages in reply to phil fenner, 11-05-2002 14:31:53
Phil,
Do you mean the physical abuse or the electrical abuse? If physical, maybe the type of insulation be be more important than the gauge of the wire. Routing it I suppose will also play an important part.
If electrical, I doubt it will be a problem. If you go from 6v to 12v, the current drops by half so wiring from a 6v system is overkill if you convert to 12 (notice the battery cables on a 6v system for example).
It would be nice to just know what the original wiring was though...
Jim
Phillip J. Fenner
11-06-2002 11:03:07
 Re: Re: Re: Re: Re: Re: wire guages in reply to Jim W, 11-06-2002 10:19:24
Jim, I am talking physical abuse and especially the wire strength, not insulation but that helps. It may be a red herring, however. The insulation was the same 6 or 12v I would presume. One mystery is why the 20 amp fuse used in 6v systems is retained in the 12v light systems when clearly it could be halved, so I presume they kept the same wire guage too, maybe to keep the parts list simple as it is not a big cost issue.
Phil F
