Thermostats (again)
Glenn Smith
10-28-2002 20:44:51
I want to put a thermostat in my TEA20. My MF dealer says they are n/a. Does any one have a part number from NAPA or from some other sourse for one and a gasket here in Canada?
TONY
11-02-2002 11:25:29
 Re: Thermostats (again) in reply to Glenn Smith, 10-28-2002 20:44:51
The TEA20 is just a standard car motor, so most thermostats will fit. Just a matter of selecting temperature. Usually quite a bit of corrosion around the top pipe and alloy assembly. I have often read that it is unwise to run without a thermostat, as it actually makes cooling worse without it?
I had problems with overheating and unsoldered the top header off the radiator, poked a dip stick down the tubes (carefuly!) and it been perfect ever since.
James,UK
11-01-2002 08:12:36
Glenn,
We can get them over here in the UK really easily. If you have any trouble, email me, and I'll forward some details of suppliers over here. Most of the tractor places here don't use this nasty electronic mail stuff, and webs are still what spideys spin!!
Good luck.
Jim W
10-31-2002 10:40:56
Glenn,
The thermostat in a TEA does not go in the hose like on a TO; it fits in a casting like on a car. I am sure they are available someplace. I'll check mine when I get home for a part #, and whether it is the same size as the Triumph one. If it is, they are easy to get. I am pretty sure it's a 70 degree model (160 F).
Jim
Glenn Smith
10-31-2002 11:29:05
 Re: Re: Thermostats (again) in reply to Jim W, 10-31-2002 10:40:56
Hello Jim
I used the old Triumph car trick at a local NAPA and found a thermostat that should fit. I haven't found the time yet to install it. If it does not fit they said I could return it. The tractor part site suggested below in another post lists thermostats for both the TEA's and TO's one for a housing like mine and one for the hose like a TO. However it did not list a new part number. I did not check it out further because they are to far away from me anyhow.
Thanks
Glenn
Jim W
11-01-2002 07:50:07
 Re: Re: Re: Thermostats (again) in reply to Glenn Smith, 10-31-2002 11:29:05
Glenn,
I had forgotten that I have a NOS MF thermostat at home. I checked it out last night; it's a bellows type (which should help slightly with the bypass hose deal) but to my surprise it's only 140F!
Maybe someone can comment why a tractor needs to run so cold. I can't remember seeing a thermostat that low before.
Jim
Ray,IN
10-29-2002 18:25:55
I've lost my receipts, but a search will find posts with the NAPA, and Carquest numbers. I just visit the local Carquest store and request a stat for a TO30. They have reference catalogs for Harry Ferguson parts. The same stat fits the TO20 and 30- into the top radiator hose, and I suspect fits all Harry Ferguson tractors with the same top hose.
Joe B in Houston
10-29-2002 06:34:11
Glenn, If you can not find one try going to www.trustytractor.com. If they do not have one listed e-mail them. They seem to be able to find most anything. Good luck Joe
