Re: TO-35 Chasing Low Oil Pressure. Camshaft Bearings.
Jim L WA
05-25-2020 09:58:34
Tractor guy, You said, "When the water temp stabilizes at the top of the green water temp band, then the oil pressure is 10-15psi at mowing RPM. and barely any needle movement at idle." Do you mean it's dropping to zero at idle or is it just above zero, like 5psi maybe? If so, I would think it's going to require a complete tare down and rebuild. So if it were my tractor, I would just keep using it until you have to do it. When you detect a knock at idle then go for it.
