Re: TO-35 Chasing Low Oil Pressure. Camshaft Bearings.
Ed H. -OH
05-24-2020 11:53:45
Hello, Had same issue with a perkins in a to35, Dropped the oil pan, pressurized the oil system with an electric pump and oil, oil came gushing out of the bottom of the gear cover, pulled it , found mount bolt for an idler gear came loose, was under pressure,easy fix..... .you may find your leak the same way.....Ed
