Re: TO-35 Chasing Low Oil Pressure. Camshaft Bearings.
Ed H. -OH
05-24-2020 07:50:24
Hello, I worked on a to35, with a perkins diesel, for low oil pressure, pulled the pan,pressurized the oil system with a pump to see where the loss was, started poring out below the front cover, pulled the cover and found idler gear mount bolt came loose that had oil pressure..makes a mess but will tell you where the loss is.....Ed
