The Real deal on Mineral Oil in the TO20
35 series
Joe B in Housto
10-22-2002 10:16:03
I have read several messages about using mineral oil in the gear box / hydraulics on the TO35 that I have. I currently have 80/90 (I think) oil in it. The only problem I have is that the Hydraulics drop quickly when the tractor is off or the clutch is pressed in.
Is the mineral oil thicker.? I think I may need to replace the Master control valve in my Hydraulic pump but might the mineral oil help.?
Hmmmmm m... Things that make you wonder....
Norm in Ont
10-22-2002 19:47:30
 Re: The Real deal on Mineral Oil in the TO20 - 35 series in reply to Joe B in Houston, 10-22-2002 10:16:03
Phil is probably right on this one but I would like to add that maybe you should change your oil with the proper type being Mineral 80-90 if you are not sure of the quality. Massey dealers sells it as M1103 with GL1 designation.
Norm
Phil (VA)
10-22-2002 10:24:26
Probably not. If your lift drops quickly when you depress the clutch, and assuming you have it full of some type of decent fluid, probably it is a relief valve or some such and not the fluid.
