TO-30 outer thrust washer
John - Michigan
10-16-2002 15:13:47
Two problems - when I went to rebuild a 1953 TO-30 with the continetal engine, the outer thrust washer was broken into three pieces and laying in the oil pan. Where can I get a replacement and what would cause this?? Also had 3 bent push rods - this tractor was parked 25 years ago.
Duner Wi
10-16-2002 16:50:44
 Re: TO-30 outer thrust washer in reply to John - Michigan, 10-16-2002 15:13:47
If you have the TO 30 style bearings with the single flange front bearing and a thrust washer the thrust washer set is Sealed Power # MB 1403W.
Main bearing set with single flange is # MS 259B . If you have the TO 20 style bearing with the straight shell Part # is MS 260B. Thrust washers come with the MS 260B. I don't know why the thrust washer broke. I will guess the push rods got bent from stuck valves.
