Start button?
t.abbott
10-13-2002 18:11:07
I have a to35 with two buttons on the console. The one on the right starts the tractor the one on the left does nothing. What is the intended purpose? Does any one know where to purchase the cast iron "U" shaped muffer piece & muffler? Thank You, T.Abbott
James, UK
10-17-2002 08:07:03
 Re: start button? in reply to t.abbott, 10-13-2002 18:11:07
Follow the wiring loom/rats nest - you may well find it is connected to a heater plug in the air intake - at least, that's what it was like on a TEF diesel - and I think early Fordson Dextas were the same. It was pre the time they woke up and put one heater plug in each cylinder.
The other button may be a later add-on using a starter solenoid to operate the starter.
t.abbott
10-21-2002 18:27:32
 Re: Re: start button? in reply to James, UK, 10-17-2002 08:07:03
Thank you. Is this what would plug into the air intake that has like a fuel line going to it and another connected to the fuel tank? Thank you, T. Abbott
Norm
10-14-2002 16:54:49
Normally the left push button is the actual start button. On mine it is and is original. Is it diesel engine?
t. ABBOTT
10-16-2002 18:24:19
 Re: Re: start button? in reply to Norm, 10-14-2002 16:54:49
Yes it is deisel.
zipper, never buttons
10-14-2002 10:08:47
I only had fergies starting by the gear lever or the ign. key, never a button.
My fergies all have the horn button to the left. For the availability of exhaust parts, check out:
www.bareco.com.au
they have a distributor in CA. Ask them for nearest retailer.
