TE20 Drag link ends
Ron in WI
10-13-2002 12:51:51
Wonder if anyone out there knows a source for these. I need both front and one rear drag link ends.
Any/all help appreciated.
Ron
Ron in WI
11-01-2002 15:44:24
 Re: TE20 Drag link ends in reply to Ron in WI, 10-13-2002 12:51:51
Found a great resource for TE 20 drag link ends and other parts. www.sparex.com They come right back to you with answers, and will supply nearest dealer to you. Thanks for all great help!
Jim W
10-13-2002 17:41:08
I can get them here in Ontario at my local UAP/NAPA dealer. Do you have those in WI?
Jim W
Ron In WI
10-14-2002 17:27:27
 Re: Re: TE20 Drag link ends in reply to Jim W, 10-13-2002 17:41:08
Thanks for the info Jim. We have NAPA, but doesn't have the prefix you sent. Would you or someone know if the ends for the TO20 would work on the TE20, or is there just enough difference?
Ron
Jim W
10-15-2002 07:38:21
 Re: Re: Re: TE20 Drag link ends in reply to Ron In WI, 10-14-2002 17:27:27
I think maybe here UAP was bought by NAPA. Anyway now that I think of it I suspect these guys source these parts from Vapormatic.
Jim W
James, UK
10-15-2002 04:11:29
They should be the same, as Harry was into parts commonality in a big way - but it may be worth checking with someone like "The Old 20 Parts Company" here in the UK +44 1322 792698 I've found them very helpful - but beware of the time difference
Am I right in thinking that the TO30 was what we knew as the FE35? Two gear levers, two brake pedals on the right, and ground speed or constant PTO? Can anyone advise? If it is the same as the 35 series, then you may find that the drag link ends off an MF135 will fit. Your local MF dealer or tractor factor should carry these in stock.
