Is it a TO 20 or a TO30?
James Riley
10-09-2002 15:21:17
I have a Ferguson tractor that I need help identifing.
On the cast aluminum housing around the steering
column is a plate giving the serial # TO30 100.
Oil filter is inside the oil pan.
The engine serial plate is so rusty, in cleaning
it up, will probably destroy it.
It has a Wagner front end loader #1501 F. Ser.270.
A scraper on the rear which is 67" wide, can't find amfg. name.Thanks, Jim R.
phil fenner
10-10-2002 13:04:00
 Re: Is it a TO 20 or a TO30? in reply to James Riley, 10-09-2002 15:21:17
You have a 1950 TO-20.
James Riley
10-09-2002 17:14:25
Addendum: Another couple of questions.
Instrument panel is similar to MF parts book, Issue 1,12/63. Part # 825 036m91 for a TEA 20.
Has no air filter hole thru it.
Are their obvious differences between a Z120 and Z129 engines? Thanks again, Jim R.
Ford Man
10-09-2002 17:46:30
 Re: Re: Is it a TO 20 or a TO30? in reply to James Riley, 10-09-2002 17:14:25
The Z120 used on the TO-20 has the oil filter inside the oil pan . The Z129 used on the TO-30 has an external oil filter . Mine has Z129 cast on the block in letters about 1/2"-3/4" high .
A TO-30 has the air filter hole in the dash .
Ford Man
