TO-20 OR TO-30???
Craig
10-07-2002 19:46:36
New to the FERGUSON TRACTORS.Im going to look at a Ferguson TO-20 OR TO30 TRACTOR.Can anyone tell me the main differences?Horse Power,Tires ,rearend ??And did they make a decent loader for these models?Where is the serial numbers located ?Model number also?ARE they worth the same as a 8n or9n ford?? Thanks for your input, Craig...
Phil (VA)
10-08-2002 09:02:42
 Re: TO-20 OR TO-30??? in reply to Craig, 10-07-2002 19:46:36
Serial number should be on riveted plate on dash. TO-20 has oil filter inside pan. TO-30 has external oil filter. TO-20 has engine number beginning Z120.... TO-30 has engine number beginning Z129.... The Fergies are both four speed with overhead valve engine. Much superior to 9N which is 3 speed flathead. Although also a flathead, the 8N does have four speed tranny and position control, a nice feature which has to be added on to the Fergie (about $80). Generally you can get more tractor for your dollar with the Fergies. The red belly Fords have a mystique that adds some sheckles (sp?) in some quarters. Biggest thing to look out for on the Fergies is cracked block, as they were prone to that if they got overheated. I think a TO-30 in good tune will outpull a similar 8N.
