Ferguson F40
Gary
10-07-2002 18:00:29
third party image
Can anybody tell me what these markings are? They are located on the left side of the engine (Continental Z134).
Paul in NM
10-09-2002 19:39:42
 Re: Ferguson F40 in reply to Gary, 10-07-2002 18:00:29
Gary, those are the casting numbers. Your engine is a Continental Z134 engine.The A500 shows which specs were used as their were about 13 different specs used for the Z134 engine. Some had different blocks. For example, the TO-35 had the same engine but the early models had no opening in the block for a power steering pump. It's casting number will be different than yours as you have an opening for the PS pump in yours, no doubt.
Paul
Gary
10-10-2002 08:22:00
 Re: Re: Ferguson F40 in reply to Paul in NM, 10-09-2002 19:39:42
What are the funny markings to the left that resemble the face and hands of a clock?
cdmn
10-14-2002 09:56:42
 Re: Re: Re: Ferguson F40 in reply to Gary, 10-10-2002 08:22:00
Foundry date code, etc. Each day, they change the date codes on the wooden pattern before they start making molds. Some companies use letter codes, or numbers that can be translated back to the date the casting was poured, which particular pattern, (if duplicates are used), or even which particular furnace and pour it came from.
This helps to track down defects in case of warrantee claims, etc. Wooden patterns tend to get pretty beat up, and sometimes a piece of one gets shifted and then you might get a too-thin casting before you notice.
Some companies use standard calendar dates, which allows you to estimate the date of manufacture. Castings usually have to sit around a while and age before machining and assembly. If you aren't careful about this, you may end up with stress cracks in the casting. If a batch has problems, they find all of those with the same date code, and send them back to the furnace to be melted down again. There are various treatments for the melted metal that will improve the casting, such as a small amount of nickle particles or chips.
Foundries are wonderful! Noisy, hot and firey, full of movement, full of danger and excitement.
Every town used to have one, but now they are mostly in third world countries.
