TO 35 Deluxe? or TO 35?
Don F.
10-07-2002 08:58:23
How can I tell which it is?
Norm
10-08-2002 18:50:10
 Re: TO 35 Deluxe? or TO 35? in reply to Don F., 10-07-2002 08:58:23
Don, Do not give up just yet. As I mentionned earlier press the clutch to see if it gets harder once past the halfway down mark. If it does it is a good indication that it is a dual clutch. Now when the engine running, you should press the clutch all the way down and if it is a dual clutch, engage motor PTO setting on your lower left hand. If it engages without grinding still a good sign. Then release clutch and the PTO should engage. When you depress halfway the clutch the PTO should still run and pressing the remaining portion it will stop which is what a dual clutch is designed for.
I strongly recommend you get Big Dean's CD, it is priced very reasonably and contain lots of info. not mentionned in any manuals. It is a must.
Here's the link:
Link
Good Luck
Norm in Ont.
Don F.
10-09-2002 07:19:38
 Re: Re: TO 35 Deluxe? or TO 35? in reply to Norm, 10-08-2002 18:50:10
Thanks As soon as I get my starter problems worke out I`ll know more!
steve19438
10-08-2002 06:32:30
do the early (55) TO-35's have the "SGM" on the serial number plate? (if it is a deluxe)
Norm
10-07-2002 18:09:59
Don, On the nameplate beside steering column there should be the serial number starting with letters. If it says SGM and number, it is a deluxe. A deluxe has a dual clutch for the PTO allowing to stop tractor and still have PTO and hydraulics in operation. The clutch when depressed should feel harder on the last half which when fully depressed will stop PTO.
Norm
DonF. I guess its not a deluxe
10-08-2002 09:13:07
 Re: Re: TO 35 Deluxe? or TO 35? in reply to Norm, 10-07-2002 18:09:59
I guess its not a deluxe as I dont see any other letters other than TO. Thanks
