Starter switch for TO-20
Mike Ring
10-05-2002 01:23:01
I have a 1950 TO-20 with a bad starter switch. Are there any replacement parts, if so what are the part number or who can I contact? Thanks Mike
Jim Battarbee
10-13-2002 10:26:54
 Re: Starter switch for TO-20 in reply to Mike Ring, 10-05-2002 01:23:01
Why does yours need replacing?
Most times, I have found the problem with them to just be crud on the terminals. Disconnect the ground from the battery and remove the wires from the starter switch. A wire brush or sandpaper used on all contacts should solve your problem. If not, take the switch off and check the contacts on the under side. A small file will re-new them.
steve moyer
10-07-2002 13:05:59
THE MASSEY FERGUSON DEALER IN MY AREA HAD THEM IN STOCK.
Mike Ring
10-07-2002 18:51:01
 Re: Re: Starter switch for TO-20 in reply to steve moyer, 10-07-2002 13:05:59
Steve. Would you happen to have the part number for the starter switch? Thanks Mike.
