Starting with gear shaft
Mattias Carlsso
10-03-2002 04:29:34
I have a TEF-20 which runs well. My problem is that the gear shaft can't be used to "activate" the starter motor. I think it is jammed in the gear box. What can I do to fix this?
Regards
Mattias
Henning Hertz
10-08-2002 06:44:29
 Re: Starting with gear shaft in reply to Mattias Carlsson, Sweden, 10-03-2002 04:29:34
Byt kontakten
Pete@easttn
10-03-2002 05:04:40
Mattias,
The 4 bolts holding the starter switch, loosen these and slide starter switch all the way toward rear of tractor. The four holes in switch are slotted to allow adjustment. If this don't work may need new switch which can be purchased from Sparex part # S.42538 some people will give you a number from NAPA but if your tractor is a TE-20 it will not fit. Also Bareco from Aussie land sells same switch, they have a distributor in United States.
Pete
