To-20 Radiator Problem
Ryan Martin
09-29-2002 17:30:00
I have a To-20 that had oil-like sludge in the radiator. I flushed the radiator and used a radiator cleaner that my local NAPA recommended, but the sludge has come back. Does anybody know what may be causing this? There is know water in the oil so I think the block is still intact.
Ray,IN
09-29-2002 20:33:17
 Re: To-20 Radiator Problem in reply to Ryan Martin, 09-29-2002 17:30:00
A compression check will identify the source. I suspect a leaking head gasket. Try retorquing the head bolts to find a loose one-or more. This "oil-like sludge" has to come from inside the engine, unless an enemy has been visiting your tractor shed.
