Low oil presure on TO-20
terry
09-24-2002 17:52:27
hello ive just installed new oil pump and new gauge but am only showing 20lbs psi hot or cold.but if i un hook the oil presure line the oil squirts really good,im suspecting a bad gauge,any help would be greatly appriciated
Rusty
09-25-2002 15:16:25
 Re: low oil presure on TO-20 in reply to terry, 09-24-2002 17:52:27
That is really good for a 50 year old tractor. Only way to do better is replace the bearings and sleeve the cam journals. But 20 is better than most. Would not worry.
Tony
09-27-2002 11:48:56
 Re: Re: low oil presure on TO-20 in reply to Rusty, 09-25-2002 15:16:25
The manual says that pressure will be low at tickover, no worries I would think if the engine sounds ok.
Ray,IN
09-24-2002 19:52:30
Terry, The pressure is sufficent. The original type gauges are not accurate, and if the rocker arms aren't clattering with the visible pressure you have don't be concerned. The pump is limited to 30psi by a relief valve. Do a search of this board for oil pressure and you'll find many excellent explanations.
