Zane sherman helped me
dan ct
09-23-2002 10:41:53
I recently purchased a 1952 T30 thaat that came with a 7' Meyers plow up front.It had no conrols except for partial up off rear hydraulics.I called Zane Sheman,after our first conversation he knew how to solve my problem.He designed a conrol valve which gave me up and down,left and right control of this otherwise useless blade.He talk me through all my weak areas ,which included hydraulics and plumbing.In one weekend I got everything installed and lo and behold no leaks and it works perfectly. I even asked him to make up the hydraulic line with the sizes I specified and with the quick connects I asked for.I called him a dozen times and he always had time to help me. I am also sending some tips to Zane which maybe helpful to the next person who does a live thang or a Zane thang on a T30. So any one out there who is trying to jury rig a hydraulic system for blade or bucket on the front of a t20 or t30 I highly recommend calling Zane Sherman,he is easy to talk to and not hard on the pocketbook either.
Dale in WV
09-23-2002 16:59:14
 Re: zane sherman helped me in reply to dan ct, 09-23-2002 10:41:53
With access to a workable Meyers plow and a jeep that runs it on its last legs, how were you able to configure that plow to attach to a TO-30?
And how do you get the hydraulics? I'm supposing a hydraulic drive that works off the front end of the tractor, right? New at this older tractor stuff, but willing to expand its utility.
ZANE
09-24-2002 10:12:25
 Re: Re: zane sherman helped me in reply to Dale in WV, 09-23-2002 16:59:14
Thanks Donny for the nice testimonial!
It was nice doing business with you.
Enjoyed all the telephone conversations.
As for the jeep hydraulics, You could use a small oil reservoir and a belt driven hydraulic pump and a two spood control valve to operate the three cylinders on the plow but it would take a little Yankee injinuity to do it.
There is also a self contained 12 volt hydraulic system that is fairly enexpensive that could be used to accomplish the same thing.
Zane
