Two questions
glen
09-17-2002 16:16:47
Frist question on my Ferguson Tea 20 which way does the thrust washer go one side has groves under cut and the other side have a smoth side when I took it apart I did not take note of this .Second question While instaling center main bearing my cap must have not seated properly when removing it after a torque to check the plastigauge I could see the cap bearing had bunched up where it meets the other bearing It is scrap I think .Can you buy one bearing? or do they only come in sets I ask you guys first before going back to the store
Jim W
09-18-2002 10:04:08
 Re: two questions in reply to glen, 09-17-2002 16:16:47
1. The grooves in the thrust washers go toward the moving faces, i.e. the crankshaft.
2. I have only seen the main bearings in sets, but maybe someone else knows differently.
Note also that both of these are the same parts as used in a Triumph TR2-4. You may be able to get lower prices from a parts supplier for British cars. Try the link below.
